- Thu Dec 24, 2015 7:38 am
#186772
I receiving an error message when I try to add the Neopixel library to my Photon Redboard. I was unable to find definitive information online in regards to this. Not sure if having a Redboard as opposed to just a Photon could be causing the problem?
Any information or help would be greatly appreciated. I have posted the error message below. (it lists multiple issues).
Thanks,
Gary
neopixel/neopixel.cpp:60:4: error: #error "*** PLATFORM_ID not supported by this library. PLATFORM should be Core or Photon ***"
In file included from neopixel/neopixel.cpp:50:0:
neopixel/neopixel.h: In constructor 'Adafruit_NeoPixel::Adafruit_NeoPixel(uint16_t, uint8_t, uint8_t)':
neopixel/neopixel.h:99:5: warning: 'Adafruit_NeoPixel::pixels' will be initialized after [-Wreorder]
*pixels; // Holds LED color values (3 bytes each)
neopixel/neopixel.h:95:5: warning: 'const uint8_t Adafruit_NeoPixel::type' [-Wreorder]
type; // Pixel type flag (400 vs 800 KHz)
neopixel/neopixel.cpp:65:1: warning: when initialized here [-Wreorder]
Adafruit_NeoPixel::Adafruit_NeoPixel(uint16_t n, uint8_t p, uint8_t t) :
neopixel/neopixel.cpp: In member function 'void Adafruit_NeoPixel::show()':
This looks like an error in neopixel library. Would you like to create an issue on GitHub to let the author know?
CREATE ISSUE
CREATE ISSUE
CREATE ISSUE
CREATE ISSUE
CREATE ISSUE
CREATE ISSUE
CREATE ISSUE
neopixel/neopixel.cpp:63:48: error: 'pinHI' was not declared in this scope
#define pinSet(_pin, _hilo) (_hilo ? pinHI(_pin) : pinLO(_pin))
neopixel/neopixel.cpp:135:9: note: in expansion of macro 'pinSet'
pinSet(pin, HIGH); // HIGH
CREATE ISSUE
neopixel/neopixel.cpp:63:62: error: 'pinLO' was not declared in this scope
neopixel/neopixel.cpp:271:9: note: in expansion of macro 'pinSet'
neopixel/neopixel.cpp:429:9: note: in expansion of macro 'pinSet'
neopixel/neopixel.cpp:565:7: note: in expansion of macro 'pinSet'
pinSet(pin, LOW); // LOW
make[1]: *** [../build/target/user/platform-8neopixel/neopixel.o] Error 1
make: *** [user] Error 2
Thanks,
Gary
CREATE ISSUE
CREATE ISSUE
CREATE ISSUE
CREATE ISSUE
CREATE ISSUE
CREATE ISSUE
CREATE ISSUE
CREATE ISSUE
