- Thu Sep 24, 2015 1:08 pm
#184905
Hey all!
I recently purchased the aforementioned stepper motor and am attempting to discern which wire leads where. I'm following a bildr tutorial here as I am also using an EasyDriver with the same model motor.
In the illustrated layout it pairs the following wires for each motor -- red and green, yellow and blue. However, the wires that came with mine are green, blue, red and *black*. In this case is the yellow the same as black? I'm primarily concerned with mixing which should be pos/neg. The data sheet can be found here.
If this helps, they come out in pairs which you can see in the picture below.
Thanks in advance!
Thanks in advance!
