- Sat Jun 27, 2015 7:02 am
#182956
I put together my redbot shadow chassis kit and everything is working great except the accelerometer.
AngleXY (which I'm guessing should give me the "direction" of the bot) is not giving sensible values. I checked AngleXZ and angleYZ which gave accurate results. Now when I rotate the bot along XZ, angleXZ increases normally, but angleXY also increases, which I find odd.
I'm using the redbot library and the code from experiment 8-1 Accelerometer Read.
Here's some samples:
Laying still on table ([xz, yz, xy]):
Moving 0-90 degres along XY ([xz, yz, xy]):(-560, -272, 16304) -- [-1.97, -0.96, -115.91]
(-496, -224, 16368) -- [-1.74, -0.78, -114.30]
(-480, -240, 16304) -- [-1.69, -0.84, -116.57]
(-400, -208, 16336) -- [-1.40, -0.73, -117.47]
(-448, -224, 16368) -- [-1.57, -0.78, -116.57]
(-464, -240, 16352) -- [-1.63, -0.84, -117.35]
(-640, -208, 16256) -- [-2.25, -0.73, -108.00]
(-592, -176, 16304) -- [-2.08, -0.62, -106.56]
(-560, -176, 16256) -- [-1.97, -0.62, -107.45]
(-576, -160, 16272) -- [-2.03, -0.56, -105.52]
(-608, -112, 16224) -- [-2.15, -0.40, -100.44]
(-528, -240, 16320) -- [-1.85, -0.84, -114.44]
(-576, -192, 16304) -- [-2.02, -0.67, -108.43]
(-512, -112, 16352) -- [-1.79, -0.39, -102.34]
(-496, -208, 16352) -- [-1.74, -0.73, -112.75]
(-544, -112, 16320) -- [-1.91, -0.39, -101.63]
(-432, -160, 16368) -- [-1.51, -0.56, -110.32]
(-432, -256, 16336) -- [-1.51, -0.90, -120.65]
(-416, -240, 16368) -- [-1.46, -0.84, -119.98]
(-480, -208, 16320) -- [-1.68, -0.73, -113.43]
(-464, -128, 16336) -- [-1.63, -0.45, -105.42]
(-544, 0, 16432) -- [-1.90, 0.00, -90.00]
(-592, -384, 16336) -- [-2.08, -1.35, -122.97]
(-496, -256, 16304) -- [-1.74, -0.90, -117.30]
(-512, -240, 16320) -- [-1.80, -0.84, -115.11]
(-528, -208, 16240) -- [-1.86, -0.73, -111.50]
(-272, -224, 16304) -- [-0.96, -0.79, -129.47]
Moving 0-90 and 90-0 degres along XZ ([xz, yz, xy]). Notice that XY changes similar to XZ.(-144, -384, 16224) -- [-0.51, -1.36, -159.44]
(-16, -432, 16336) -- [-0.06, -1.51, -177.88]
(-256, -416, 16384) -- [-0.90, -1.45, -148.39]
(-16, -432, 16368) -- [-0.06, -1.51, -177.88]
(-128, -848, 16320) -- [-0.45, -2.97, -171.42]
(352, -1472, 16144) -- [1.25, -5.21, 166.55]
(1408, -2512, 15840) -- [5.08, -9.01, 150.73]
(-2064, -1696, 17488) -- [-6.73, -5.54, -129.41]
(80, 5200, 25392) -- [0.18, 11.57, 0.88]
(-2080, 2432, 21792) -- [-5.45, 6.37, -40.54]
(-128, -1328, 18000) -- [-0.41, -4.22, -174.49]
(1680, -496, 19424) -- [4.94, -1.46, 106.45]
(-1472, -2624, 14528) -- [-5.79, -10.24, -150.71]
(-2160, -1168, 16160) -- [-7.61, -4.13, -118.40]
(-1168, -2944, 15616) -- [-4.28, -10.68, -158.36]
(624, -896, 16240) -- [2.20, -3.16, 145.15]
(-384, -176, 16160) -- [-1.36, -0.62, -114.62]
(-1920, 64, 16944) -- [-6.46, 0.22, -88.09]
(-192, -960, 16800) -- [-0.65, -3.27, -168.69]
(-1952, -48, 16656) -- [-6.68, -0.17, -91.41]
(1168, 1488, 15072) -- [4.43, 5.64, 38.13]
(-240, 11424, 22624) -- [-0.61, 26.79, -1.20]
(9200, -1856, 5888) -- [57.38, -17.50, 101.41]
(12400, -208, 11360) -- [47.51, -1.05, 90.96]
(13616, -2608, 5376) -- [68.45, -25.88, 100.84]
(31312, -7488, -13216) -- [112.88, -150.46, 103.45]
(15904, 432, 4480) -- [74.27, 5.51, 88.44]
(15952, -1024, 3888) -- [76.30, -14.76, 93.67]
(16064, -1040, 3392) -- [78.08, -17.05, 93.70]
(16144, -896, 3520) -- [77.70, -14.28, 93.18]
(17936, 16, 4032) -- [77.33, 0.23, 89.95]
(15136, 1488, 6496) -- [66.77, 12.90, 84.39]
(10048, -384, 9648) -- [46.16, -2.28, 92.19]
(6256, 224, 15456) -- [22.04, 0.83, 87.95]
(4368, -2016, 14512) -- [16.75, -7.91, 114.78]
(656, -4080, 15616) -- [2.41, -14.64, 170.87]
(-2080, -1952, 15120) -- [-7.83, -7.36, -133.18]
(96, 208, 16064) -- [0.34, 0.74, 24.78]
(-400, -1168, 15632) -- [-1.47, -4.27, -161.10]
