Here it is; nothing fancy. The (few) comments are in swedish so I guess they aren't of much use to you.
But you should be able to figure this out easily if you have done PIC ASM before. All it does is:
- Init ports on the PIC
- Init display
- Init RS-232
- Wait for image data
The image data recieve loop waits until three bytes have been recieved, bitshifts every byte two steps and then sends the complete pixel. Set your terminal program to 8-bit mode, one stop bit, 19200 baud and no flow control.
Code: Select alllist p=p18f452
include "P18F452.INC"
ERRORLEVEL -203 ; suppress annoying column directive message
ERRORLEVEL -205 ; suppress annoying column directive message
ERRORLEVEL -207 ; suppress annoying column message
ERRORLEVEL -302 ; suppress message because of page change
CONFIG WDT = OFF
CONFIG OSC = HS
CONFIG OSCS = OFF
CONFIG PWRT = OFF
CONFIG BOR = OFF
CONFIG CCP2MUX = OFF
CONFIG STVR = OFF
CONFIG LVP = OFF
CONFIG DEBUG = OFF
CONFIG CP0 = OFF
CONFIG CP1 = OFF
CONFIG CP2 = OFF
CONFIG CP3 = OFF
CONFIG CPB = OFF
CONFIG CPD = OFF
CONFIG WRT0 = OFF
CONFIG WRT1 = OFF
CONFIG WRT2 = OFF
CONFIG WRT3 = OFF
CONFIG WRTB = OFF
CONFIG WRTC = OFF
cblock 0x00
delayCounter1
delayCounter2
delayCounter3
byteCount
Red
Green
Blue
endc
;Kommentarerna gäller bara för 8-bitars 8080-interface.
RST equ 5 ;Reset (då 0)
ERD equ 2 ;Read data (då 0)
RW equ 1 ;Write input (då 0)
D_C equ 0 ;Data / Command (Data 1, kommando 0)
lcdData equ PORTD ;8-bitars dataport
lcd equ PORTC ;Kontrollport
;constant Addr_disp = B'01000100'
org 0x0000 ; Begininning of Program EEPROM
goto main
;org 0x0008
;goto ISR ;Interrupt Service Routine
main
clrf TRISC ;Port C blir en utgång
clrf TRISD ;Port D blir en utgång
bsf TRISC,7 ;... utom ingången för serieporten (RX)
movlw d'64'
movwf SPBRG
movlw b'00000110'
movwf TXSTA
movlw b'10011000'
movwf RCSTA
bsf RCSTA,SPEN ;Enable serieport!
clrf lcdData ;Nollställ pinnarna...
bcf lcd,D_C ;Välj att skicka kommando
bsf lcd,ERD ;Vi vill inte läsa något...
bcf lcd,RW ;Vi vill inte skicka något heller...
call sendReset ;Men en reset vill vi minsann dra!
movlw 0xa0
call sendC
movlw 0xB4
call sendD
movlw 0xa1
call sendC
movlw 0x00
call sendD
movlw 0xa6
call sendC
movlw 0xad
call sendC
movlw 0x8e
call sendD
movlw 0xb0
call sendC
movlw 0x05
call sendD
movlw 0xb1
call sendC
movlw 0x11
call sendD
movlw 0xb3
call sendC
movlw 0xf0
call sendD
movlw 0xbb ;Pre-charge voltage
call sendC
movlw 0x1c ;R
call sendD
movlw 0x1c ;G
call sendD
movlw 0x1c ;B
call sendD
movlw 0xbe ;Set VCOMH
call sendC
movlw 0x1f
call sendD
movlw 0xc1 ;Set contrast
call sendC
movlw 0xaa ;R
call sendD
movlw 0xb4 ;G
call sendD
movlw 0xc8 ;B
call sendD
movlw 0xc7
call sendC
movlw 0x0f
call sendD
movlw 0xca
call sendC
movlw 0x7f
call sendD
movlw 0x15
call sendC
movlw d'0'
call sendD
movlw d'127'
call sendD
movlw 0x75
call sendC
movlw d'4'
call sendD
movlw d'131'
call sendD
movlw 0xaf
call sendC ;display on
call delay120ms
; movlw 0x8e
; call sendC ;Clear window
; movlw d'0'
; call sendD
; call sendD
; movlw d'131'
; call sendD
; call sendD
; call delay120ms
bcf PIR1,RCIF
movlw d'3'
movwf byteCount
USARTloop
btfss PIR1,RCIF
goto USARTloop
bcf PIR1,RCIF
movff Blue,Red
movff Green,Blue
movff RCREG,Green
decfsz byteCount
goto USARTloop
movlw 0x5c
call sendC
rrncf Green
rrncf Green
movf Green,0
call sendD
rrncf Blue
rrncf Blue
movf Blue,0
call sendD
rrncf Red
rrncf Red
movf Red,0
call sendD
movlw d'3'
movwf byteCount
goto USARTloop
;SUBRUTINER---------------------------------------------
sendD
bsf lcd,D_C
bcf lcd,RW
movwf lcdData
; call delay1ms
bsf lcd,RW
return
sendC
bcf lcd,D_C
bcf lcd,RW
movwf lcdData
bsf lcd,RW
bsf lcd,D_C
return
sendReset
bcf lcd,RST
call delay120ms
bsf lcd,RST
return
delay1ms
movlw D'130'
movwf delayCounter1
movlw D'7'
movwf delayCounter2
delay1msLoop
decfsz delayCounter1,1
goto delay1msLoop
decfsz delayCounter2,1
goto delay1msLoop
return
delay120ms
movlw D'255'
movwf delayCounter1
movlw D'255'
movwf delayCounter2
movlw D'10'
movwf delayCounter3
delay120msLoop
goto delay1msLoop
goto delay1msLoop
decfsz delayCounter3,1
goto delay120msLoop
return
end
