- Fri May 29, 2015 4:09 am
#182318
I have installed the Atto Pilot 180A version into a 6s multirotor setup. I want to use it to measure current and sent it to a telemetry port on the Rx.
There are 3 pins out GND, V and I
GND + V works fine and gives me approx 1.5 v reading corresponding to around 24v which sounds right. (The max reading is about 50+v which steps down to 3.3v)
GND + I however has a reading of zero. I think the atto pilot is supposed to convert the current reading into a 0-3.3v signal to correspond with 0-180A.
It's not working so I'm looking for any suggestions.
Note: My soldering looks pretty bad but I have done continuity tests which appear to be ok. No shorts and the multirotor powers up fine.
Can bad soldering or overheating while soldering compromise any parts?
Thanks for any help.
