- Wed Mar 25, 2015 5:55 pm
#180716
Hi there,
I just received my Wav Trigger, hooked it up to an external amplifier module and started playing with it.
I am noticing that when I connect a trigger to ground (any of them) the trigger happens intermittently. Sometimes the triggers will work normally and play in fast succession. Other times when I bridge the trigger/ground pin, nothing happens.
I have tried setting the triggers to various modes, both normal and random and there is no change in this intermittent behavior.
I did install headers as Mr. Robertson had suggested. I have double checked all of the solder joints and they are all good clean joints. Any ideas why this is happening?
