- Sat Aug 19, 2006 5:43 am
#17520
It takes about 70%, depending on the bitrate. I have considered libmad, but chosen the Helix library because its memory/CPU requirements were better documented.
The elm-chan file system is a great piece of software. It's easy to use, fast, has low memory requirements and good documentation. I have used EFSL before I switched to the elm-chan lib, and found it a bit overengineered and not very well documented.
