- Tue Jul 25, 2006 5:22 pm
#16229
I'm working on a project right now and I have an nRF24L01 and a 74hc165 parallel-to-serial shift register hooked up on my SPI bus. From the looks of the datasheet, the 165 doesn't go into high impedance on its output when the chip is disabled. With that said, should I put a tri-state buffer between the 74hc165 and the SPI MISO pin so that, when disabled, the 165 will look like high impedance to my SPI port?
As an FYI, I have both of the chips working correctly separately, but I haven't tried them simultaneously yet.
