- Thu Jan 16, 2014 7:48 pm
#167335
Hi everyone, I am trying to monitor load from 230V socket outlet to check there if the switch is on/off.
I am trying to convert 0.4490vac when it is 5A from the current transformer to 1-5vdc because of my transmitter (4-20mA)
The current transformer i'm using is CST-1005 - http://www.mouser.com/catalog/specsheets/CST-1005.pdf
I came across this thread- https://forum.sparkfun.com/viewtopic.ph ... 15#p129154
But the circuit is for 50A, I do not understand the calculation of the circuit to get 3vdc and must i use the same diode? I only have IN4007 to test out.
I tried the circuit but it doesn't work for me.
Thank you
Thank you
