- Tue Jul 11, 2006 10:04 am
#15670
Hello everyone.
I'm trying to use the 18F2550 along with its USB module.
I would like to use it with Full Speed (12Mb/s) which requires a 48MHz clock to drive the USB Module.
My question is, is it possible to run both of these, the PIC CPU and the USB module off of the same internal clock?
If not, I also have a 4MHz resonator at my disposal, and would like some input as to how I should set this up for optimal use.
Also, if someone is using this same PIC with teh USB module, if you could post your setup, that would help also.
Thanks in advance!
Thanks in advance!
