- Sun Apr 28, 2013 12:26 pm
#158946
Hi, My name is Martyn for England & am a complete novice with electronics, i,m making a 7amp hr 12 volt battery powered charger for the familys mobile phones while camping, i have a 4 watt solar panel to keep it topped up, the battery, a 4 port self powered usb hub, my question is, can i use a 12volt to 5volt dc converter if i modify a usb cable for positive & negative from the output side of the converter, if so what wattage dc converter should i get (seen 5 watt & 25 watt ones on ebay) & also, will i need a reverse charging diode in line aswell
I have tried to get what info i can from the net, but the last thing i want to do is fry our mobile phones if i get it wrong
Thanks in advance for your help, most looking forward to your suggestions
Martyn
Martyn
