- Sat Apr 27, 2013 12:49 pm
#158936
i want a circuit without a on switch. The schematik is attached below. A battery may be connected through K8 (Power In) and be charged trough an external charger circuit connected at k9 (Bat_load). There are 2 LDOs. U2 powers an MCU. U1 powers some sensors. To switch it on, an external signal on K3 (On) may power the MCU. Afterwards, the MCU keeps hisself enebled through the POWER_ON signal. The external signal at K3 may be diconnected. The MCU enebles U1 through "Sens ON".
Will the circuit work as i want it to do?
Thank you in advance
Hami
Hami
