:?: Narrowing the beam of a ultrasonic rangefinder?
Posted: Tue Mar 19, 2013 5:12 am
by ckambiselis
I was wondering if someone has attempted to mechanically narrow the beam of a Maxsonar ultrasonic rangefinder
https://www.sparkfun.com/products/9491?
I checked with Maxbotix and they told me this will require a paid NRE fee for the engineering time to narrow the beam, or consider buying one of the outdoor editions which costs 5-6 times more. But I was wondering if the cone is actually narrowing the beam or is it only in the design of the transceiver electronics.
I know that the EZ4 has the narrowest beams but also shorter detection range of human figures (at least that's what it says on the pattern graphs).
Re: :?: Narrowing the beam of a ultrasonic rangefinder?
Posted: Tue Mar 19, 2013 7:56 pm
by stevech
probably not viable due to reflections, but you could try, with simple megaphone-like materials that dampen ultrasonics. Such as you find in an anechoic chamber (q.v.)
Posted: Wed Mar 20, 2013 2:05 pm
by CircuitBurner
Yea, an acoustic cone would mechanically narrow beam and reception, but depending on material used there could be either distortion in the measuring calibration or reduction of range/sensitivity.
Similar to how microwave communications 'horn' antennas work, specifications are affected by whatever frequencies the antenna will be use with.
Like, a trumpet flare on a Tuba mouthpiece wont sound nearly as loud and full (wide bandwidth) as the Tuba flare on the correct mouthpiece.
So, its possible to craft a reflective horn to the correct dimensions for ultra sonic waves (sub-radiowaves) to narrow your beam and detection angles with minimum losses... I dont know exactly what that equation is now, but it indeed exists.
get the horn dimensions wrong, and you could effectively kill the efficiency and output of the waves you are sending out.
Got time and $$, just build a set of varying scales of design range, test them all, and settle on the one that worked best...Edison style//
Posted: Fri Mar 22, 2013 11:18 pm
by Duane Degn
I found this recently.
https://www.virtuabotix.com/?question=m ... th-hc-sr04
It's for a sensor with two transducers. It might work with your Maxbotix too.
Posted: Sat Mar 23, 2013 1:33 pm
by Mee_n_Mac
@ the OP :
What beamwidth are you looking for ? What's the problem with the existing sonar ?
Posted: Sun Mar 24, 2013 3:23 pm
by Dave Mueller
You could put the sensor at the focus of a parabolic reflector. You'll need to match the beamwidth of the sensor to the reflector diameter and focal length.
