- Fri Jun 30, 2006 6:05 pm
#15170
OK, I've noticed that on a lot of the PCB's you can get from SFE, there are rather large capicitors on anything that has a 7805 regulator. Also, one of the tutorials said this was extremely common to see...
Seeing as how I use a 7805 regulator and (possibly) 2 LM317T regulators, and not a single capicitor, I was wondering If I should start using a cap, or two or three...
Anywho, I understand that the capicitors (termed decoupling caps), reduce noise from the power supply line, but I have no idea what sizes to use, and from what I got from the tutorial about the large cap, the bigger the better?
Now, I have 2 820uF 200V caps, and about 5 2200uF 16V caps (from a PSU that died on me....), so I've got some fairly large caps at my disposal if need be, lol (will it even work with these?!)
I guess, what I would like to know, is how to tell when caps are necessary, and how to decide which ones / how many / and in what configuration to use them.
Much thanks!
~Nate
Much thanks!
~Nate
