By waltr
#154147
That you will not easily find (I've looked). Best you can do is hub that you then attach a wheel to.
Question: What does the wheel do?
Is this to drive a small robot? If so then that motor directly attached to a wheel will not work.
Instead what you need is a gear motor that has less RPM and more Torque.
By bigmuddyfoot
#154151
I am just prototyping right now, I was thinking about future projects and though I would get wheels all at the same time for a future car pargect
By Duane Degn
#154164
I second waltr's warning about the motors you linked to. The only way they will power a vehicle with a wheel directly attached to it is if the vehicle is going down a steep incline. Those motors will not be able to power a robot with wheels directly attached to them.
I purchased several of these motor/wheel combos from MPJA. They didn't work at all. Without a gearbox, the motors couldn't move their own weight.
You'll need one of SparkFun's (or other vendor's) motor with a gearbox in order to power a robot or other ground vehicle.
There are a variety of ways to mount wheels to gear motor axles not originally intended for each other.
Here's an example of mounting Vex Mecanum wheels to Rover 5 axles (post #29 of thread).
Pololu and other robot supply places sell mounting hubs for a variety of axle sizes to make it easier to mount wheels.
By chartle
#154172
I'm with everyone else.
Your prototype car will not move. Well maybe if you give it a good shove and get the wheels and motors moving, but it will have no torque at all and the smallest incline or bump will stop it.
I would go to http://www.pololu.com/. Pretty sure thats where Sparkfun gets some of their motors and wheels or at least its the same supplier. They have a much better selection of gear motors and wheels.
