Page 1 of 3
LiPo Charging
Posted: Thu Dec 06, 2012 12:57 pm
by kirash4
I'm looking for a circuit that functions similar to what a laptop would do: when it's plugged in, it charges the battery, and when unplugged it runs off of battery. You can plug/unplug at any given time without having to power down.
All of the LiPo charging circuits I've seen are just that, to charge a battery. How can I expand a circuit to also allow power to be supplied to a device while at the same time also charging the LiPo (if needed) and when power is removed, the LiPo takes over and keeps things running? And when power is re-applied, it recharges the LiPo while also supplying it to the device.
Thanks all!
Re: LiPo Charging
Posted: Thu Dec 06, 2012 2:11 pm
by viskr
How much power? How big of a battery?
For small batteries there are single chip solutions, as power goes up, external MOSFETs are needed.
So for cell phone sized batteries this device at SparkFun works well -
https://www.sparkfun.com/products/10161
For larger sizes, you might take a look at some of the Linear Technology parts.
Re: LiPo Charging
Posted: Thu Dec 06, 2012 2:23 pm
by kirash4
That charges a battery and supplies power to the device itself? I thought it only charges ...
As for how much power ... the entire device can at any given point be pulling as much as 2A, so the external power supply is going to be supplying at least that. The LiPo we're thinking of using TWO single cell 6600mA. Wired separately. Reason for this is redundancy, if one fails, the other will continue running and giving us the ability of swapping the dead one out. So, each one will have its own charging/monitoring circuit. If external power is removed, we want both batteries to take over and power the device.
Re: LiPo Charging
Posted: Thu Dec 06, 2012 3:04 pm
by viskr
Re: LiPo Charging
Posted: Thu Dec 06, 2012 4:26 pm
by viskr
PS I was curious to see what Maxim had, and this might be what you are looking for, Ti also plays in this arena
http://datasheets.maximintegrated.com/e ... X8903Y.pdf
You will need to add a load sharing circuit externally, which in the simplest could be some big Schottky diodes, or a couple MOSFETs.
Re: LiPo Charging
Posted: Thu Dec 06, 2012 4:28 pm
by MichaelN
You can normally just run it directly from the battery. If the charger is plugged in, it will supply current to the load as well as charging the battery; if it's not plugged in, the battery will supply the power...
Re: LiPo Charging
Posted: Thu Dec 06, 2012 6:56 pm
by kirash4
Ok, I'll research those. Next, will there be any problems if I designed two separate circuits for two separate LiPos and have both get fed by the same Vin, and have both circuit's Vouts power the device? Each one will charge/monitor each battery, but when needed, both need to supply the device with power.
Re: LiPo Charging
Posted: Thu Dec 06, 2012 7:22 pm
by viskr
Independent charge circuits for each battery is the proper way to go, you just have to be careful to make sure you have large enough capacitors on the shared Vin to minimize the voltage variance when the inductors switch in. With up to 2A you are talking about a lot of energy.
Simple load sharing can be done with diodes, which means the more charged battery picks up the load first, and as the internal switches on these chargers/supplies are MOSFETs you don't face thermal run-away like you would with bipolar transistors.
Re: LiPo Charging
Posted: Thu Dec 06, 2012 8:16 pm
by kirash4
What do you call "large enough" capacitors?
Do you have an example of load sharing with diodes? I just assumed I can tie Vouts together and call it done.
Re: LiPo Charging
Posted: Fri Dec 07, 2012 9:11 am
by viskr
No 2 supplies tied together is not redundancy. If one fails it will drag the other one down. The simplest would be some schottky diodes rated for the load
As for the capacitor size, at least double the recommended input filter cap the circuit spec sheet suggests, and probably 4x would be better.
Re: LiPo Charging
Posted: Fri Dec 07, 2012 9:31 am
by kirash4
Wouldn't the diodes cause a voltage drop though?
Re: LiPo Charging
Posted: Fri Dec 07, 2012 9:37 am
by viskr
Yes you would lose 0.5V, but that is just the simplest circuit.
You could also design one with MOSFETs that would accomplish the same thing, but with voltage drops being quite small.
Never parallel supplies by just hooking them up, they never will have exactly the same output voltage, and they will end up fighting each other.
Re: LiPo Charging
Posted: Fri Dec 07, 2012 11:30 am
by kirash4
Alright, that makes sense. if I use Linear's ICs for their buck/boost capabilities, it'll be a bit of a waste because with the voltage loss from the diodes, I'm back at 4:5V and I need 5V ... hrm. Need to think about this.
Re: LiPo Charging
Posted: Fri Dec 07, 2012 8:46 pm
by Duane Degn
kirash4 wrote:it'll be a bit of a waste because with the voltage loss from the diodes, I'm back at 4:5V and I need 5V ... hrm. Need to think about this.
Doesn't the buck/boost happen after the "load" connection? Since the diodes are placed before the regulator and not after, your curcuit should still see whatever voltage the regulator is outputing. Right?
Re: LiPo Charging
Posted: Fri Dec 07, 2012 9:07 pm
by kirash4
A LiPo supplies 3.7V only. I need both 3.3V and 5V for the device, so I'll need a buck/boost between the LiPo and the device itself. When the device gets plugged in to 5V, I need to both charge the LiPos and continue to power the device.
Since I'll be using two LiPos, viskr suggests using diodes to tie them together prior to getting to the device. I'll still need to buck/boost that to get the necessary 5V.
