- Thu Aug 09, 2012 2:23 pm
#148310
Hello, all!
I have a need to enclose the pins of an opto-interrupt sensor and a couple of resistors that will be soldered to the o-i's pins. I need to enclose them in a small plastic tube (1/2" OD, 3/8"ID). I know that some substances, like silicone caulking, would be bad for this purpose (due to substances being released during curing that are corrosive, e.g., acetic acid in the case of common silicone caulk).
Someone suggested to me to use "regular epoxy." Well, I'm not sure what that is, since there are so many types these days. I would also appreciate using something that can be purchased in either small or larger quantities, without great expense. UV and/or waterproof protection is *not* required. Some flexibility in the filler substance would be *nice* (i.e., no rigid), but is not a firm requirement.
I'd appreciate any suggestions that you may have! I don't want to put product out there that I'd have to do a bunch of repairs on later!
Many thanks,
Deb
Many thanks,
Deb
