- Sun Aug 05, 2012 2:43 pm
#148198
I want to measure the tension in a bicycle spoke. The frequency that a spokes vibrates is inversely proportional to the length and proportional to the square root of the tension per unit area it the stress in the spoke. Therefore if the resonant frequency is measured accurately the stress can be calculated directly and the tension then calculated by multiplying by the spokes area. The length and spoke area are known quantities. Spokes are resonant in the mid audio range 200 to 2000 Hz.
IF the frequency is measured with a 2 mg gate time variation and plus minus one count error at 1 KHz the total error is about 3000 parts per million - not very accurate. IF the period of one cycle is measured at an accuracy of 1 microsecond than the accuracy improves to about 1001 parts per million and could be increased by measuring the period for multiple cycles of the input signal - for example if you took the average period of 1000 input cycles at a 1 microsecond resolution the accuracy would approach several parts per million. I would like to have enough memory to display the spoke tension in physical units possible even correcting for spoke dimensions.
I am looking at DEV-11021 Arduino Uno-R3 or DEV-10140 Frequency Counter both with ATmega 328 cpu or the UBW32 with a PIC32 CPU. I believe that the PIC with 32 bit timers and the higher clock frequency would be the better choice but have not programmed any of the new chips. Which of these would give me sufficient resolution? What are your recommendations? Please explain your recommendation, i.e. cost, development tool available or?
Thanks
Thanks
