By daok
#147636
I have a sensor that has some males pin which need to be connected to Arduino.
When prototyping, I use the breadboard but now that I would like to have everything more solid do I have to solder directly a wire from the sensor to Arduino or it exist a kind of wire with one side with male pin and one side with female pin?
Thank you
By Duane Degn
#147638
One way is to plug the pins of your device into a breadboard and then use normal hook up wire.
The easier way is to get some M/F jumpers.
http://www.sparkfun.com/products/9139
http://www.sparkfun.com/products/9140
http://www.sparkfun.com/products/9386
http://www.sparkfun.com/products/9385
I usually get 100 at a time now. You'll wonder how you ever got by wtihout them.
By smolek
#149630
Duane Degn wrote:One way is to plug the pins of your device into a breadboard and then use normal hook up wire.
Thanks alot, :violin:
