- Tue Jul 10, 2012 7:52 pm
#147252
Hello, I'm new to the site.
I don't have much experience in digital electronics so please keep it simple. Let me give you some info prior to saying what I want to do. I own a Subaru Impreza WRX with a straight cut dog engagement manual transmission, and with a dog engagement transmission to shift under full throttle you can either slightly lift off the throttle to "unload" the gears in the transmission to allow you to shift and mesh the dog gears together, or you can cut fuel or retard the ignition timing to effectively unload the gears by slowing the engine.
I like things automatic, so I'm looking at doing the latter. Problem is, I don't know much about proximity sensors, photoelectric sensors, hall effect or anything else similar to these. I'm basically looking at attaching 2 or more sensors so that when the gear lever is in gear it will either allow a signal through it or block a signal through it but when the lever is pulled slightly it will do the opposite. I need something that g-forces won't affect and that will be able to function anywhere in the range of -40F to 140F since it will be on the inside of the vehicle. Another thing, I'm willing to use a pressure sensor or something similar to a strain gauge if at all possible since it may work better than any sort of proximity/photo/laser type sensor.
Any help would be greatly appreciated!
