- Tue Feb 21, 2012 5:29 am
#140111
hi..
i think i might be missing something with the 3rd hand, my main activity now, is to solider wires to a board (like power wires to IOIO, or wires to a current sensor)
now the best way to do so , as i look at it is to have the board upside down trapped by one arm, a wire in the other, and hold the solider and iron myself.
there are to problems , the first, is that i switch on the the iron and try to position the board horizontally, my hands are VERY close to the iron holder, (which is also hot), and i have fight my way through it.
the second problem, is that i understand you don't need to have the iron and solider both on the wire, but have the iron , heat up the wire then apply the soldier letting drip to the board across the wire, BUT, it doesn't work, i have a 25W iron (i understand you need 25-30 for electronics) and you need to bring iron the solider really really close to each other on the wire, otherwise i'm assuming the heat dissipates before it has a chance to melt the soldier. on the other hand i don't want to touch the board accidentally with the solider as it might damage it.
