- Fri Feb 03, 2012 8:19 am
#139208
I know this has been discused many times, but I just wanted to be sure.
I'd like to build an integrated car charger (I'll place it right behind the cigarette lighter and use it's power source). Since I can only get 12V and I need 5V, I figured it'd be best to use a linear regulator (in this case, a 7805 should do).
My phone's wallcharger says it's 5V/1A, but since 1A is the maximum output of a 7805 (and it would produce a lot of heat) I figured I should lower the current somehow. Will the lowering of the current help to cool down the IC?
Thanks!
Thanks!
