- Fri Feb 24, 2012 4:56 pm
#140301
I definitely want to use EEPROM memory for this project. I'm actually getting ready to map out the EEPROM addresses and the serial command strings for the uOLED displays. If I have enough memory on the system, I want the system to be configurable without an actual PC. I really want to keep the Arduino portion of the build, and because it's more "open source" that way. I love how easy the Arduino is to "pick up and running with". If other people pick this project up to play with, they will do amazing things with it.
Yes, I I can probably knock $20 dollars or more off the final price by going with a plain ATMEGA-something, but I'll lose that very low "knowledge level" needed to tinker with it (and the pre-existing USB support).
It's not ready for the Sparkling homepage. Right now it's not exactly pretty, but and nothing close to integrated. I need my proto-board to come in so I can try hiding it in an AEG.
I should also work on the basic fire control program, and using functions so that it's tidy... Oh yeah.. There's the small matter of the barrel chrony which is going to require interrupts (probably).
A hearty thanks for the vote of confidence, and though!
Static
