- Fri Jun 24, 2016 4:45 am
#190379
StaticDet5 wrote:The MOSFET is getting hotter n' hell. How hot is too hot? I pulled out my thermometer and got around 150 Fahrenheit. I've got a heatsink on it (I'm aware that it is going to get hot), but do I need to consider a thermal check on the system?If the hotest it ever gets is 150F then you're OK. That's about 65C, which will certainly feel hot to the touch, but enough below the 85C where I'd be worried. Can I assume you have a think layer of thermal paste between the FET and the heatsink ? If not then do this, it will help. The datasheet for the FET should have some curves for max current vs case temp.
