- Tue Dec 06, 2011 4:37 pm
#136668
Hi there, looking for answer to a basic electronics question from my perspective of not really knowing that much on the subject. I am wondering if it is possible to design a circuit that operates two sub-circuits of different voltages, so they can interact. If I already put my foot in my mouth and lost you let me try to explain a bit more clearly.
I have one circuit that consists of a 3.3V signal that is sent by a PCB-based timer in regular intervals from a battery to a servo. This operates one servo which is on when the voltage is sent, and off when there is no voltage present. An example application is to have the servo on for 10s, then off for 2, then on for 10, etc. until otherwise directed by the user.
The other circuit consists of a 12V gear motor that moves the servo around. Right now the motor is either on, or off - meaning that the servo is moving while it is on. What I want to do is to create an overall circuit design that would "read" that the 3.3V circuit is actively sending voltage to the servo, and interrupt the 12V circuit. So in other words, the motor would cease to move the apparatus while the 3.3V circuit was live. I want the 12v circuit to die when the 3.3V circuit is active.
No I'm a dummy when it comes to these things. Would I use a mechanical relay that opens a normally closed switch in the 12V circuit?
I know I can do this via Arduino but I want to see if there is a simpler hardware solution. If anyone has any ideas, I would love some feedback and references to what I would need to buy on Sparkfun to build it.
Thanks!
Thanks!
