- Tue Nov 22, 2011 6:22 pm
#136090
Hey everyone,
I'm working on a toy tank project that uses these 2 parts:
Serial motor driver - http://www.sparkfun.com/products/9571
Dual motor gearbox - http://www.sparkfun.com/products/319
I'm having trouble getting the motors to move when VCC for the driver exceeds 4V, even though the drivers are supposed to run from 5-16V and the motors from 3-6V. I'm sending the commands using a MSP430F5438 dev board through UART pins. At 4V the motors operate correctly most of the time, but other times only 1 motor will run and I have to send the command again before the other motor starts. At 5V or above VCC every time I send a command the motors start to run but then suddenly stops. I made sure I have a common ground and even tried adding capacitors to the motor connections thinking it might be noise but no luck.
I'm pretty lost at this point, the only thing I can think of is that these 2 parts aren't compatible or the motors aren't getting enough torque. Any ideas?
