- Fri May 05, 2006 9:31 pm
#13143
I have just received a serial accelerometer from sparkfun and I am trying to understand how it works.
I have the serial connection connected to a serial gender changer, and the gender changer connected to a cable which goes into the DB25 serial port on my computer.
I have never worked with Hyperterminal before so I am not sure if I am using it correctly.
After I open a new connection, the "Connect To" screen opens and my only choices are "sofware modem", com3, and, tcp/ip. I always choose com3 but I can never get a response from the accelerometer.
I have two serial ports on my computer. How can I tell which port is Com1, Com2, or Com3? Will the accelerometer work with the setup I am using through the DB25 pin serial port? If I used a serial to USB connector, would this solve my problems?
Thank you in advance.
