- Tue May 02, 2006 7:31 pm
#13011
To convince myself I could 1) design a PCB 2) assemble it and 3) have it actually work, I made up a little Altera CPLD breakout board, and ran it through BatchPCB. The PCBs showed up over the weekend, the parts from digikey on monday, and today I sat down and soldered it.
Soldering on the 44 pin TQFP was about fifty bazillion times easier than the 0603 caps. Next time I'll use bigger caps. At least I went for unpolarized caps.
So, my problem: I programmed it with just a XOR gate, and it seems to work, except logic high is about 3.3V, not 5V. This is with an EPM7064STC44-10, which should be 5V only. (Their CPLDs in larger packages have VCCIO pins for doing 3.3V logic, but not this one.) Anyone have any ideas what could be going on?
(Oh, lesson learned: move silk screened text away from parts that will cover it up.)
