- Sun Jun 12, 2011 8:22 pm
#128645
Hi all!
I am making my own lipo tester to check cell balance and the percentage of available power on my battery packs.
The problem i am having is that i want it to be universal for a 2s thru 6s pack, but when nothing is connected to one of the ADC ports the value floats around. Would using a diode to ground the adc channel, bringing it to zero be the correct way to fix this ? Then if a cell was connected to that ADC port, power would flow through the ADC and not right to ground. From what i have read on diodes this seems like it would work. Am i correct, or is there a better way ?
thanks
thanks
NO, not that switch!
www.randomnerd.com
www.randomnerd.com
