- Tue Apr 11, 2006 2:30 pm
#12177
Depends. Do you want to use the camera for anything else, or will this live the life of a servo camera from here on out?
I've been meaning to grab a refurbed/Ebay cheap but functional long zoom digicam and hack into it to make a PIC drive ALL the controls. Use a cable or RF transmitter to send the video out back to a TV, and some control scheme to control the PIC. Now, the question is, how does current flow? Are the controller inputs the high voltage potential, or is that on the far side of the button? You'd have to solder transistors or other driver circuitry between the switch contacts and have them triggered by the PIC. Very simple after you figure out your switches.
Switches + communication would still leave enough time to drive a couple of RC servos to add pan and tilt to the motorized zoom.
Now, if you want to keep the camera whole and functional, you have a few other options. A push solenoid or an RC servo would definitely work, but you may have issues if some part gets bumped out of position. Depending on the camera, some have IR remote sensors that would work if you can determine the protocol, others have sockets for a remote switch that would allow you to "plug in" and have a solid electrical path.
(addendum) And this once again proves why I need to actually write instead of add thoughts to a post over the course of 30 minutes or so
Technical Alchemy
