- Sat Feb 19, 2011 1:54 am
#120671
Hi all,
Currently I'm working on a hobby project where I'm trying to build an accellerometer, xbee, 8 RGB leds, and li-po cell into a juggling ball.
With a lot of creativity, I want to get some special light effects, by using the accellero data. We know when a juggling ball is in the air when there's no gravity measured.
I really have a lot of ideas, but one for which I've already written the code and works, is this one:
- Suppose you have a good juggler who's able to throw every ball the same height. Then, on every throw, the balls go invisible up. And they fade in blue when they are going down. At the catch they light up white, a computer speaker sounds "splatch", and the ball turns invisible again. Now image this effect with three or four balls, or even several jugglers, stereo effects, etc...
It's like simulating a "rain" effect.
The PCB design and schematics are almost ready, the only question I still have is which xbee fits the best.
- How would the movement of a balls impact the reception of the Xbee. I know there is a doppler-effect, but after all, the balls are not moving extremely fast, just the earths gravity on a maximum of 3 or 4 meter height.
- How does the rotation of the balls impact the reception. What if an Xbee is caught upside-down?
- Which series (1 or 2) should I choose? I think this is point-to-multipoint or broadcast. (one computer with usb-attached xbee, and maybe 14 juggling balls all having their own xbee.)
- Do you think the 1mW is sufficient? It's mainly for indoor juggling. Take an average podium/stage size (5x5 meters), and the computer which controls everything at the edge.
- Is the chip antenna okay?
- Does a 60mW xbee for the computer, in broadcast mode, cause better reception, even if the balls itself have only a 1mW xbee?
And a second question:
- Does anyone here have experience with trilateration, for determining the position using Xbee signal strength. It'd be great if we can have the balls light up blue for one juggler, red for the other, and when they are passing balls, they change to their own color. (I wanted to use an RFID reader for this first, but it turned out to be rather expensive...)
Thanks for any help. If I were to build only 1 ball, I'd take a pro-version, but for this much juggling balls, I hope the 1mW is sufficient, and saves the battery.
Jonathan
Jonathan
