- Mon Feb 07, 2011 7:11 pm
#119600
stevech wrote:What do you suggest? (not trying to be sarcastic or mean)wiggles wrote:You could easily run a standard serial stream over it, just hookup the serial connection to the mic/ heaphone jack (make sure to use TTL level voltages to avoid damaging the radios). You may also want to rig up some directional antennas, since it should be line of sight the whole way up. Directional antennas will also help finding it once it hits the ground.Nope
BudgetEngineer
