- Thu Jan 13, 2011 8:28 am
#117296
OK simple question to save me the job of days more looking, but I am after some 0603 LEDs with lower forward voltage drops to use on existing systems with lower voltages available. Are all LEDs based on their wavelength going to have the same Vf?
For example most red are around 2V, presumably due to the methods used to create the light. Some with higher Vf like White, UV, Pink etc... are they always going to have a 3V+ Vf, or is it techincally possible to get them at lower Vfs?
I suppose the real question is what is the lowest voltage each wavelength can have, and is there a definitive list anywhere?
My main reason is I would like some UV lights working from a system with 2.5V so I am a good 1V out of range at the moment.
