- Fri Mar 10, 2006 10:21 am
#10855
Having done some more searching, it looks like there is a really rather small number of rf parts used for these wireless controllers:
1) Signia SGN5210 modules several versions marked 6,7,8.2, all seem to be pin compatible - GND & VDD on pins 5 & 6.
2) Signia SGN5210 modules with different pinout, GND 1 & 11, VDD 2 - the one that started this discussion.
3) Nordic nRF2401 modules - Pretty much exactly as sold by Sparkfun, but with varying pinouts - grab the datasheet, trace the pins and you are good to go.
4) Unkown COB part on a module that looks very like the Signia modules, but has a different set of signals - recognizable by having the feed on the PIF antenna at an angle, a large printed inductor and bieng fed from a 13.842Mhz xtal. Mad Catz have electronics for both this and the Signia modules, and either can appear in the same packaging.
5) 'TITAN DDS' modules - unknow COB part
6) rfwave RFW102 modules - datasheets available.
...) Various other parts - Cypress Wireless USB, TI, Phillips, Chipcon
If you can find a controller off the shelf that is using the nordic or rfwave modules, then you are in really good shape - well documented and, having used the 2401, very easy. However, round here, all the available controllers use (1) or (4) from above, so I grabbed one for research. (20 quid - funny looks from the shop staff as I tried to peer thru' the translucent plastic)
(My interest in this is that I am have built some RF trancievers for my own projects - using chipcon 2500, and it would be useful to make comparisons)
TTFN
SamL
