- Tue Oct 05, 2010 1:38 am
#110801
I've received 4 LCDs of Nokia 6100 type from China, but they seem to be modified. I can't understand the pinout, as it is not working neither with the code example for Philips controller nor of the Epson one.
The usual pinout in documentation is this:
What is printed beside the connector of Chinese Nokia LCD is this:
Next strange to me, is the 9th and 10th pin. I must be able to connect +6.5 to it for back light (BL) but two of my LCDs burnt when doing that The situation with them is that if I connect 3.3v regulated, they light on in pale blue that I still can't say the LCD is turned on. If I connect 5v regulated, the light deceases! May be these LCDs are modified having a booster and works with 3.3v for BL.
I next connected it to Arduino, used tutorial code for Philips controller from Arduino playground, but it didn't work. Seems nothing changing. Then I downloaded Epson code to Arduino and wired as explained, but also didn't work (even though the LCD started to blink very lightly and fast).
Reading whole lots of posts on forums didn't help as no kind of tutorial code I found still helps with these LCDs and no post on forums was exactly to discover the difference of Chinese Nokia 6100 with the original one.
Please give some ideas, how I can make sure what the controller is, and put the LCD to work.
