- Sun Oct 03, 2010 1:01 pm
#110700
I recently purchased an Arduino Duemilinove and an 8 pin Picaxe Motor driver board: http://www.sparkfun.com/commerce/produc ... ts_id=8317
I have looked through the documentation ( http://www.rev-ed.co.uk/docs/AXE023.pdf ) numerous times, and no matter what I try with the arduino, it will not have an effect through the board to the motor.
Could someone please show me exactly what wires go where, and then what signals I need to be sending through them?
Here's a poor drawing of one of the methods I've tried so far:
I hope I haven't shorted the board out or anything. I just want to be able to control the motor through the board.
If its relevant, I haven't made any modifications to the programming it came with (and the little switch is set to RUN).
Thanks.
EDIT: I was being retarded. The board is a stand-alone board, thus it can't be controlled via an arduino, and it needs to be programmed separately using a Picaxe controller cable thing.
Thanks.
