- Sat Oct 02, 2010 4:41 am
#110616
Hello everybody,
i need some advice for my project. I want to create a circuit that will have this characteristics:
1) when it detects some movement it will start to fade in - out a led.
2) the range of the detection could be veeery small. e.g. i just want to activate the led on off sequence when the user move his hand in front of a sensor.
3) it has to be portable so i need some type of battery
4) is has to be small.
I did some research and was thinking to use an avr like teensy or the arduino nano or mini and connect a led and an pir sensor like this one http://tinyurl.com/252cxko .
Am i looking in the right direction? Is it possible to attach such type of sensor to these boards?
What type of battery should i search for and how much time is the whole system supposed to be powered by it?
Can this system be done without using an avr by just only using plain elements eg. capasitors transistors resistors etc??
Thanks in advance..
Thanks in advance..
