Battery backup for memory in Arduino Duemilanove
Moderators: phalanx, TS-Tim
Postby sdisselhorst » Wed May 12, 2010 3:45 pm
Is there an easy way to save the memory of the Arduino using a battery backup of some kind? I want to avoid my counters zeroing out from brief power loss. I am powering them with +5v from a regulated power supply tied right to the +5v points on the prototyping board. I also have +12v from the power supply available. I haven't been able to find a good solution anywhere on the web.
sdisselhorst
Re: Battery backup for memory in Arduino Duemilanove
Postby busonerd » Wed May 12, 2010 5:39 pm
Power supply -> schottky diode -> +5V
Coin cell - >schottky diode -> +5V
Make sure you don't try to run anything but the AVR off the onboard +5V, or your coin cell won't last very long.
--David Carne
busonerd
Ex-SFE Guru
Postby trialex » Wed May 12, 2010 6:52 pm
Depending on how you are using these variables - i.e. how often they update, you could store them in EEPROM - it is not cleared when power is removed. There is 512 bytes available, and a library to show you how to do it.
trialex
Postby sdisselhorst » Thu May 13, 2010 5:57 am
I am running a 20x4 lcd screen off of the same 5v. Isn't there some way to just put power right to the chip for memory backup?
sdisselhorst
Return to SparkFun Product Questions
Who is online
Users browsing this forum: No registered users and 2 guests
