- Fri Apr 30, 2010 1:43 am
#99812
Sorry of some of this has already been covered...
This may sound daft, but can you stick a voltmeter on AC between the uP board and the ground of the PC you are using. I have seen sparks (PSU leakage current from my PC) to items that are grounded (scope probe, surprised cat...).
Leakage current can be a pretty good way of killing things as you plug/unplug things.
If you are still killing boards, try adding grounds to everything and make sure that your ground pin connects where is should.
As David says, how about some photos.
Have you felt and static zaps in the immediate area ? Modern electronics can have it's life span significantly reduced after being clobbered with static, but it should make you jump if you are part of the discharge path.
Are you actually totally killing the whole CPU or are you clobbering the boot loader when things die ?
-Mark
