- Tue Feb 16, 2010 10:18 pm
#93687
I just got an arduino a couple days ago and have only taken a java class but i think it turned out ok. here is the code for the board. I borrowed the temp and time stuff from others and modified it to suit my needs. let me know if you have any suggestions. ill be starting the wood and fiberglass work as soon as i gets a bit warmer.
//Wine Cooler v.01
//02-16-2010
/*This project is a simple design for a temperature controlled
cooler complete with lighting and a serial monitor to the PC.
NTC 10k Thermistor Schematic:
(Ground) ---- (10k-Resister) -------|------- (Thermistor) ---- (+5v)
Analog Pin 0
Pin List:
Analog 0 10K_thermistor1 +Voltage Divider with 10K Potentiometer
Analog 1 10K_thermistor2 +Voltage Divider with 10K Potentiometer
Analog 2 reed_Switch and Coil Trigger when brought high.
Analog 3 Menu_Set_Button +10K Resistor to Ground
Analog 4 Menu_up_Button +10K Resistor to Ground
Analog 5 Menu_Down_Button +10K Resistor to Ground
Digital 6 Menu_Left_Button +10K Resistor to Ground
Digital 7 Menu_Right_Button +10K Resistor to Ground
Digital 8 Relay1_Peltier 230W@12V,19.6A attached with transistor 2n2222 and diode
Digital 9 Relay2_Heat_Exhaust_Fan attached with transistor 2n2222 and diode
Digital 10 Relay3_CCFL attached with transistor 2n2222 and diode
Digital 13 Led status light +330 ohm resistor
Digital 2,3,4,5,11,12 Display_Lines 16*2
#include <LiquidCrystal.h>
#include <math.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
const int therm1 = 0; // Cooler Temperature Sensor pin
const int therm2 = 1; // Electronics Temperature Sensor pin
const int door = 16; // Sets door pin
const int MenuSet = 17; // Menu Set Button pin
const int MenuUP = 18; // Menu Down Button pin
const int MenuDN = 19; // Menu Up Button pin
const int MenuLT = 6; // Menu Left Button pin
const int MenuRT = 7; // Menu Right Button pin
const int RelayCooler = 8; // Triggers peltier plate and fan assembly
const int RelayHeatFan = 9; // Triggers fans of control compartment
const int RelayCCFL = 10; // Triggers internal cooler light
const int ledStat = 13; // Shows status light
int setTemp; // State of the set temp from menu
float ActualTemp; // States the temp inside the cooler
float ControlTemp; // States temperature around powersupply and controller
int DoorState; // States is door is open or closed
int up; // States Pin Status
int down; // States Pin Status
int left; // States Pin Status
int right; // States Pin Status
float TimeAlive; // States the number of minutes the cooler has been on since shutdown
int second=0, minute=0, hour=0;
int set;
// Inputs ADC Value from Thermistor and outputs Temperature in Celsius
// requires: include <math.h>
// Utilizes the Steinhart-Hart Thermistor Equation:
// Temperature in Kelvin = 1 / {A + B[ln(R)] + C[ln(R)]^3}
// where A = 0.001129148, B = 0.000234125 and C = 8.76741E-08
float Thermister(int RawADC) {
float Temp;
Temp = log(((10240000/RawADC) - 10000));
Temp = 1 / (0.001129148 + (0.000234125 * Temp) + (0.0000000876741 * Temp * Temp * Temp));
Temp = Temp - 273.15; // Convert Kelvin to Celcius
Temp = (Temp * 9.0)/ 5.0 + 32.0; // Convert Celcius to Fahrenheit
return Temp;
pinMode(MenuSet, INPUT); //sets menu buttons as inputs on digital channels
pinMode(MenuDN, INPUT); //sets menu buttons as inputs on digital channels
pinMode(MenuUP, INPUT); //sets menu buttons as inputs on digital channels
pinMode(MenuLT, INPUT); //sets menu buttons as inputs on digital channels
pinMode(MenuRT, INPUT); //sets menu buttons as inputs on digital channels
pinMode(RelayCooler, OUTPUT); //sets peltier assembly as output
pinMode(RelayHeatFan, OUTPUT); //sets cabinet fan output
pinMode(RelayCCFL, OUTPUT); //sets CCFL lamp output
pinMode(ledStat, OUTPUT); //sets led output pin
Serial.begin(9600); //Start serial communications at 9600 baud
lcd.begin(16, 2); //Start lcd initialization
setTemp = 82; //Sets default temp setting
hour = 10; //Sets time. for now this is done here but in the
minute = 46; //future it will be done by the menu buttons
ControlTemp = float(Thermister(analogRead(1))); //Reads from thermistors and assigns value to float.
ActualTemp = float(Thermister(analogRead(0)));
ControlTemp = analogRead(therm2);
DoorState = digitalRead(door); //Finds out if the door is open or closed
up = digitalRead(MenuUP); //detects the state of the buttons
down = digitalRead(MenuDN);
left = digitalRead(MenuLT);
right = digitalRead(MenuRT);
float x = (millis() / 1000); //Breaks down millis() to minutes
TimeAlive = x / 60;
Display(); //cals main display function to display the current temp of the cooler
buttons(); //calls the buttons() function to execute commands based on the buttons pressed
serial(); //out puts data to serial for debugging. may also be used to set the future clock
static unsigned long lastTick = 0;
if (millis() - lastTick >= 1000) {
lastTick = millis();
second++;
// move forward one minute every 60 seconds
if (second > 59) {
minute++;
second = 0; // reset seconds to zero
// move forward one hour every 60 minutes
if (minute > 59) {
hour++;
minute = 0; // reset minutes to zero
if (hour > 23) {
hour = 0; // reset hours to zero
if (setTemp < ActualTemp){ //Compares temperature vs. setting
cool(); //starts the cooler system
else{
digitalWrite(ledStat, LOW); //if temp is ok cooler shuts down
digitalWrite(RelayCooler, LOW);
void cool(){ //function to control cooler objects
digitalWrite(ledStat, HIGH);
digitalWrite(RelayCooler, HIGH);
delay(2000);
void serial(){ //Displays serial output for debuggin but will latter be used for data logging and
Serial.print("The cooler temerature is:"); //remote control
Serial.print(ActualTemp);
Serial.println();
Serial.print("The internal temperature is:");
Serial.print(ControlTemp);
Serial.println();
Serial.print("The set temperature of the cooler:");
Serial.print(setTemp);
Serial.println();
Serial.print("Time:");
Serial.print(hour);
Serial.print(":");
Serial.print(minute);
Serial.println();
Serial.print("Time since last shutdown:");
Serial.print(TimeAlive);
Serial.println();
Serial.println();
void Display(){ //Function to run the home screen display
lcd.clear();
lcd.print("Wine Cooler is @ ");
lcd.setCursor(0, 1);
lcd.print(ActualTemp);
lcd.print("^F");
lcd.setCursor(8, 1);
lcd.print(hour, DEC);
lcd.print(":");
lcd.print(minute, DEC);
if(set = 0){
lcd.print(",AM");
else{
lcd.print(",PM");
void buttons(){ //Function to look at the button values and do the actions needed.
if (DoorState == LOW){ //checks door for left open state
lcd.clear();
lcd.print("*****ALERT!*****");
lcd.setCursor(3, 1);
lcd.print("DOOR OPEN!");
digitalWrite(RelayCCFL, HIGH);
delay(2);
else{
digitalWrite(RelayCCFL, LOW);
if (up == HIGH) { //checks the up button for temperature setting
setTemp = setTemp ++ ;
lcd.clear();
lcd.setCursor(0, 0);
lcd.print("New Temperature:");
lcd.print(setTemp);
delay(500);
else if (down == HIGH){ //checks the down button for temperature setting
setTemp = setTemp -- ;
lcd.clear();
lcd.print(setTemp);
delay(500);
else if (left == HIGH){ //checks the left button for time setting setting
lcd.clear();
lcd.print("Set Time");
lcd.print(":");
if(set = 0){
lcd.print(", AM");
else{
lcd.print(", PM");
else if (right == HIGH){ //checks the left button to display time since shutdown in minutes.
lcd.clear();
lcd.print("Time Alive:");
lcd.print(TimeAlive);
delay(10);
