- Sun Feb 14, 2010 8:56 pm
#93515
Hi all
I'm working on a project to animate a Electroluminescent display elements using a Microcontroller (in it's final form probably some Atmel chip, but an Arduino for now).
The EL wire requires high voltage AC - I've got a range inverters that drive the wire of different lengths and at different brightnesses using anywhere from 30VAC to 160VAC.
I want to switch this AC using the digital output pins of my microcontroller - I've looked at a transistor based optocoupler - specifically a PS2501 but have learned that transistors can't be used to switch AC, hence optocouplers like this one are unsuitable.
Can anyone point me at or describe a recommended method of switching such AC from microcontroller level signals?
Thanks
---Raymond
Thanks
---Raymond
