- Tue Jan 26, 2010 6:17 am
#91851
OK I will scrap the current NPN idea (it was idea in head probably not as simple as I described it), and just try the transformer circuit. I will design that up later today and post it before making it.
Also, with regards that PAGE3 ref, perhaps the 20k was for impedence matching of the sensor? Although its typically 500ohms not 20k! So I suspect its not that, it may just be for dampening as you mentioned... meh, its not really important anyway its not going to be used but its just for general interest.
I will also only pulse 5Vpp when using the transformer as if the sensor I am using that I have no specs on is limited to 50V pulses then I dont want to brick one by getting 90V+ from the full 10V drive. I can change it up after if I still don't see enough drive as I have 20 of these sensors to play with. And I now have a Prowave outdoor sensor to compare each circuit with the see the difference in behaviours.
As for the 74HC04 and CD4009 idea, are they really needed as stated before I am already getting a 10Vpp drive as it stands.
