- Sat Jan 16, 2010 3:09 pm
#90857
Anyone have some good tricks for the mechanical end of building prototypes?
I've just learned about using plastic tubing for motor to shaft connections which is a cool tip.
I have previously been using plumbers putty epoxy (i.e. Mighty Putty, but u can get better stuff at home depot for cheaper in the plumbing section) for alot of my stuff. It's awesome stuff, dries sandable & rock hard, and is usefull for much more than motor to shaft connections.
Another tip with power transmission is if you can get your motor attached to a hexagonal screwdriver bit, then that opens up a world of possibilities for transmitting power because of all the electric screwdriver/drill bits available U-Joints, flexshafts, set-screw collars (drillbit stop guides), etc. and it can handle lots of power/torque.
My current problem is how can I fab up a gear box. I have a bunch of gears from old RC cars, but Im struggling with how to mount them all & achieve the proper gear alignment & ensure they are all perpendicular. Anyone have any ideas on how to achieve this?
Someone should start a sticky with useful resources for fabing prototypes.
