- Sat Jan 02, 2010 6:01 am
#88607
I've been prototyping a number of home automation projects on breadboards. I've reached the point where one of them has the kinks worked out and is ready to be built for real.
I'm not concerned about project boxes/etc, all that is simple enough. What I'm wondering is, what do you all do about your external circuitry in this case? I have components that prohibit me from building a simple wire harness, like capacitors and resistors. Each of my home automation projects will be one-offs, so a custom PCB is really overkill it seems like (although it would be cool).
What I'd really like to have is a solder board (through hole) patterned similarly to a breadboard, in that holes are electrically connected in sets at 0.1" pitch. That would allow me to take an ATMEGA, and build up a board that has only what I really need on it, put it in a box, and have something that'll be very reliable for a long time.
Unless there's a better way? This is the first time I've ever put a prototype into long term use, so you can suggest anything!
