- Sat Dec 05, 2009 8:23 pm
#86548
Hi All,
I'm looking for a recommendation on a soldering iron. The googleing and forum searching I did came up with this Weller WP35. I went with a temp controled iron instead of a station. I plan on doing through hole and smd soldering for a while (mostly ic's and other sensitive equipment). Based on that I know I need an ESD safe iron. I'm not sure on the wattage though. The 35w @ 850f won't have any problems with under heating, but is it too much right now. Basically, should I get a lower wattage iron till I get more proficient, then upgrade the wattage? I've done a good bit of soldering in the past (but that was 8ish years ago). Also, if you all have a different recommendation on an iron I'd be glad to hear it. Thanks.
