- Thu Sep 17, 2009 9:26 am
#81265
I'm looking to connect the output of a DAC (TLV5618) to an amplified PA speaker (Speco ASPC-20). The speaker is a 12 volt amplified product yet says its input impedance is 8 ohms. The TLV5618 says not to put less than a 2k ohm load on it.
So, what's the best way to marry these two things? Should I use a "fancy" amplifier circuit like a LM386 http://www.futurlec.com/Mini_Audio.shtml or can I get away with just some discrete components since the speaker itself is amplified?
