- Sun Jul 19, 2009 11:39 pm
#77326
I posted this on the arduino forum and now I'm posting it here.
http://www.arduino.cc/cgi-bin/yabb2/YaB ... 070950/0#0\
That's that link to the arduino website but I'm posting it all here so there's no need to go there.
My project was to control the stepper motor that sparkfun sells over serial down to the microstep using an arduino and an easy driver. In the end well I succeeded. The code that I wrote for the arduino allows bi directional control of the motor down to the microstep. The bulk of the code is mainly converting the stupid ascii values that the arduino reads back into integers the last part at the end is where that magic happens.
I am uploading a youtube video of the motor and my code in action right now, it will be posted tomorrow.//VERY VERY VERY VERY IMPORTANT!!!!!
//in order to use this code for serial communications and motor control you must send the correct data sequence
//at 115200 bps, it is formated as.....1....how many characters are in the value (1 - 5).......direction (1-2).........value (DEPENDENT ON THE FIRST NUMBER)
//so if I wanted to do 3200 microsteps forward i would send 413200 over serial the first number says there are 4 characters in the value (3200) the second number is 1 which
//tells the motor to go forward (2 would go backward), and the last 4 numbers are the value.
//if I wanted to do 32000 microsteps backward for example I would send 5232000 over serial
//if I wanted to do 400 microsteps forward I would send 31400
//if I wanted to do 80 microsteps forward I would send 2180
//and finally if I wanted to do 8 microsteps backward I would send 128
//also when the program subtracts 48 from the incoming serial value its because the arduino reads the ascii value of the number not its real value so by
//subtracting 48 it converts the ascii value back into its integer value than it multiplys it by its value depending on if its tens of thousands thousands hundreds ect...
//then it adds it up and it has the value that was originally sent from the computer
//make sure the correct data is sent or else the arduino will crash and will require a reset, error handling can be programmed to suit your needs
//THE MAXIMUM INTEGER VALUE IS 65,535 AND HAS BEEN TESTED IF YOU GO OVER ERRORS WILL OCCUR BTW THIS IS ALMOST 41 FULL REVLOUTIONS
//THE MOTOR I AM USING IS THE SPARKFUN STEPPER MOTOR AND THE DRIVER IS THE EASY DRIVER V3
//1600 microsteps is equal to one revolution
unsigned int val; //pin for storing the value
int info; //variable that stores the latest serial bit from the serial port
int dirPN; //variable that stores the direction that the stepper motor will spin in
int i; //variable for the counter in the for loops
int dirpin = 3; //variable that holds the pin number of the direction pin for the easy driver
int steppin = 12; //variable that holds the pin number of the stepping pin for the easy driver
//you must connect the GND pin on the easy driver to the arduino GND as well
void setup(){
Serial.begin(115200); //opens a serial connection at 115200 bps
pinMode(dirpin, OUTPUT); //declares pin 3 as an output for direction control
pinMode(steppin, OUTPUT); //declares pin 12 as an output for stepping control
void loop() {
if (Serial.available() > 0) { //if serial data is sent this if statement will execute
delay(25); //VERY IMPORTANT delay, it can be reduced but if it is to low the arduino will not have receieved all of the serial data so reduce it at your own risk
info = Serial.read(); //reads the first serial bit
//THIS IS VERY IMPORTANT READ THE BEGINNING INTO
info = info - 48; //!!!!!!!!!! The arduino reads the ascii value so to convert it to an integer value you subtract 48
if (info == 1) { //enters if info is 1 meaning that the value is only 1 character long
dirPN = Serial.read(); //gets the next character which is the direction of the motor 1 is forward, 2 is backward
dirPN = dirPN - 48;
info = Serial.read(); //reads the single digit then converts it back to an integer and stores it in val for later use
info = info - 48;
val = info;
if (info == 2) { //enters if info is 2 meaning that the value is only 2 characters long
dirPN = dirPN - 48;
info = Serial.read(); //reads the first digit then converts it and multiples it by 10 because the first digit in a two digit number would
info = info - 48 ; //be in the 10s
val = (info * 10);
info = Serial.read(); //reads the second number then converts it and adds it to the first number it does not need to be multiplied because
info = info - 48 ; //the second number in a two digit number is a single digit 1 - 9 once added to the first number the original
val = val + info; //value that was sent is now in the arduino and will be used at the end of the loop
//the below if statments follow the same pattern as the above loops just with higher multiplying values because they are after all
if (info == 3) { //enters if info is 3 meaning that the value is only 3 characters long
dirPN = dirPN - 48;
info = info - 48 ;
val = (info * 100);
info = info - 48 ;
val = val + (info * 10);
info = info - 48 ;
val = val + info;
if (info == 4) { //enters if info is 4 meaning that the value is only 4 characters long
dirPN = dirPN - 48;
info = info - 48;
val = (info * 1000);
info = info - 48;
val = val + (info * 100);
info = info - 48;
info = info - 48;
val = val + info;
if (info == 5) { //enters if info is 5 meaning that the value is only 5 characters long
dirPN = dirPN - 48;
info = info - 48;
val = (info * 10000);
info = info - 48;
val = val + (info * 1000);
info = info - 48;
info = info - 48;
info = info - 48;
val = val + info;
if (dirPN == 1) { //if dirPN is 1 then this if statement executes, the value 1 means it goes forward
digitalWrite(dirpin, HIGH);
for (i = 0; i<val; i++) //this is the start of the loop and val the value we had to work so hard to get is the number of microsteps or in other words the number
//of times it will loop (each time it loops the easy driver microsteps) so 1 loop is 1 microstep
digitalWrite(steppin, LOW); //toggles the stepping pin on and off then delays 200 microseconds
digitalWrite(steppin, HIGH);
delayMicroseconds(200);
if (dirPN == 2) { //if dirPN is 2 then this if statement executes, the value 2 means it goes backwards
digitalWrite(dirpin, LOW);
{ //of times it will loop (each time it loops the easy driver microsteps) so 1 loop is 1 microstep
} //the serial loop ends and exits
} //the main loop runs again and awaits serial data to repeat this insane cycle all over again.....
