- Mon Dec 01, 2008 11:54 am
#60392
I have a problem I hadn't predicted. Maybe some one has some advice.
I put together a small data logger system. It is powered by a Li-On battery and a solar panel.
The hole thing works well off the battery and off the solar panel. However, when I try and charge the battery (using a Li-On battery charger) some of my IC's brake.
It works like this:
The power from the solar panel (24V) goes to a 7805.
7805 to Vin on Li-on charger.
(Li-on charger pin out = Vin,GND, Vbat)
Battery is connected to ground and Vbat.
The data logger system is powered from the battery,...which means my power line to the data logger is also connected to Vbat.
It seems like the battery charger is sending voltage spikes through the hole data logger as its trying to charge the battery.
So,......what to do...how would you charge a battery and run you IC's off the same battery while its charging. Obviously its not imposable, this is done all the time.
I was thinking of useing an R/C network to smoth the line however, I'm afraide it will damage the battery. The Li-On battery charger is sending out voltage spikes for a reason. If I smooth the line (even after the battery). Won't I be undermining the actions of the charger?
any advice????
Thanks!
JP
It works like this:
any advice????
Thanks!
JP
