- Thu Feb 26, 2009 7:43 am
#67247
It's hard to tell from the layout, but it looks like your power and ground traces are way too thin and too long. Also, the "ground" plane (which doesn't appear to be tied to ground) seems to be broken into isolated islands.
As you mention, you need bypass caps right next to all of the ICs. I also don't see the usual RC circuit for reset.
There's a trace running very close to the upper left mounting hole. I would move it so it wouldn't get damaged or shorted by the hardware.
/mike
/mike
