- Thu Jul 24, 2008 12:23 pm
#52534
http://shapelock.com/index.html
I saw this mentioned in another thread and think it's worth a separate discussion. I have a lot of questions about it but will probably buy some to play with. In a nutshell, you heat it up and it becomes soft. When it cools down it hardens. It's basically like nylon that melts at about 150F.
Anyone have experience with this stuff?
- How easy is it to mold? I'd like to be able to create a mold from other material (or even SL) and then use that to mold the SL material.
- How strong is it when cold? How brittle is it? (i.e. does it shatter easily) Does it break or deform under stress?
- How easy is it to drill/saw/machine/sand? The web site says you can but it's hard to tell how easy. I suspect that the heat of machining could be an issue.
- How viscous (uh, thick) is it when it's at 150F? How fine a detail can it pick up when molding?
Here is a Youtube video showing a case made from the stuff: http://www.youtube.com/watch?v=qEl1LXyZO98
